Everything went well today!
The truck drives awesome. up
I topped up the tank on the way home and reset the trip meter, then took a photo.
That station is 20.5 miles from the house.
I let the truck sit for 7 hours then checked the tire pressures, all were low, one by 11 pounds, the rest were less than that, one only 3 pounds low.
I topped up the PSI to equal them out.
I'll report back on the mileage after the next fill up.
My current commute ranges between posted speed limits from 25 to 65 MPH and it is about 45 minutes each way depending on any traffic concerns.
That said, here it is at home. :-)
