Nice power numbers!!
Looking at the sheet...... it appears there were some issues with the fuel flow measurements.
Neither the fuel flow or bsfc numbers make any sense.
I have not had time to digest that yet - have barely looked at the dyno sheet and I only have 2 runs printed thus far. They are making headway on the oil getting sucked in by the vacuum pump and they will replace the studs. I do not know the length of the studs - but this is a Koffel stud kit and it should be correct!
The cam is a special grind by comp cams.
I am real pleased that here were zero oil leaks. And I love my valve covers! How many B1 motors do you see with M/T cast valve covers?
