After welding in a patch panel, at what point am I doing more damage than good when grinding the weld down? Does it have to be completely smooth before applying filler? Thanks
What panel is that? Looks like a trunk drop-down. If that weld area is "hidden", more important to fill gaps then to flat welds.
