Should be lots of power/torque for the street/strip use. I look forward to seeing the rpm/hp numbers when you get a chance to type them in. Is that ~512 CID? What are the cam specs?
Yes, 512 CID. The cam is a .563/.555 lift, duration is 248/258 @.050. It's installed 4 degrees advanced.
491 rwhp at 5,500 rpm. Likely the peak, but it may hold that level a few hundred rpm more. Tons of torque!
