This is really easy guys, if you have a valid drivers license without the star right now, other forms of ID, such as a passport, may be acceptable for travel and federal building admittance but, when you go to renew your license you will have to provide the required documentation for the real ID or you are not getting a drivers license or state ID card. So as of right now unless you are in OK, Washington state or NJ you will have to provide the documentation as all the other states are in compliance with the federal law. OK and WA have been granted extensions (for how long I don't know) and NJ is still under review at this time. You may still need to provide the documentation in those states as well while they prepare to be in compliance.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
