With a pressure bleeder, open each bleeder until the fluid runs clear. Newer systems with ABS are more complex, they require a scanner to run the ABS pump.
Unless there is a ton of air in the ABS system you don't need to run the pump.
Vehicles vary, the newer LX cars even require that the car be at a certain angle (rear elevated) when bleeding brakes.
