So dusty .. are you suggesting that some dealers charge for it .. and don’t actually do it OR even try to do it ?
IIRC ... the typical dealer charge was 180$
I'm saying its not usually a suggested service item.
Clearly you got a "we don't want to do it" price, because on a non-rusty car it's a cake job.
I'm an engineer at a company that makes a lot of OEM brakes, though I work on stability control and not calipers, even our garage techs bleed by either pushing through or by using a pressure bleeder that hooks up to the cap. If a dealer had one of those, they should be done in under 45 minutes including taking the wheels off.
Even the fluid I suggested should only cost you like $15 for a liter which is enough to do anything smaller than a full size truck.
