The simplest way to narrow this down is tee a pressure gage into the fuel line. Then you'll know where the problem is.
This has been stated for days . Guess he does not want to check it.
FYI, it's not that I don't want to check it but rather that I can't at the moment as I don't own a fuel pressure gauge. I wanted to rule out the carb being the problem first before buying a gauge to check the fuel pump pressure.
You can buy combo gauge at HF for $13.00 How many days have you wasted?
The only time I have wasted is reading your posts in this thread. If all you have to contribute is smart-azz remarks why do you bother to post at all?
Since the first reply 15 days ago people have been saying fuel pressure, yet you ignore it. Why ask for advice if you won't take it? Yet when someone points out the obvious you get all hot and bothered and start name calling.
Real Men shift for themselves
