Another possibility is the main-well plugs at the bottom of the carb are porous. The plugs are aluminum and may become loose or corrode. Remove the carb. fill with fuel, elevate and watch for seepage out the bottom. Common problem on the older Q-jets. Not so much on the Edelbrock/Carter type.
