Still dealing with this issue. Is it possible for a fuel pump to pump too much fuel when it goes bad? I took the Eddy carb off today and put another one on that I have that came off of a running car a little while back. When I started cranking the motor, once gas got up to the carb it started pouring out all over the place from the top of the carb and also the plugs flooded again.
