The car has a 340/727 and 3.91 gears out back. The engine has a mild Comp 262 cam. Suspension was rebuilt using stock parts with a mix of poly and rubber bushings.
I guess I think it should ride/perform like an 80's Camaro or Mustang. It seems pretty far off from that and not in a good way.
Pop a Gear Vendors O/D on there. 3.91 with a stock 727 must rev pretty high at highway speeds.
