there will be two hoses at the pump. generally one is a pressure hose from the pump to the rack, then a return hose from the rack to the reservoir and a feed line from the reservoir to the pump.
That's with a remote reservoir, if you have a pump mounted reservoir then the line between the pump and reservoir isn't there.
