I've been working on a set of mounts for a Type II PS box to a big block. I think I finally have it figured out. This setup is fairly simple and is very rigid. I'm using 0.188 thick steel and then laser cutting and bending it. Parts are raw right now but I should have finished powder coated parts on hand in a few weeks. I'm also using a low mount 90 amp alternator in this picture. This is the new front accessory setup on the 426W block going into my '65 Coronet.
