I'm sure something could be fabricated for a SB Mopar. I ended up building my own brackets for the BB engine. I started off buying the bracket kit from Unisteer but after I bolted it on I decided it was too crappy of a design to use on my car. The type II pump is very bracket friendly. It has bolt holes that go thru the pump and the mounting surfaces are flat so it is very easy to fabricate mounting plates.
