Lew: Rick is who rebuilt this trans about three years ago. He asked me if I liked the way it shifted and at that time, I said yes. So he left the adjustments on the VB alone. I do not know if he swapped out the spring or not.
EDIT: I just found a note in his rebuild sheets ""took out his restrictor plug in case". So I must have put it in and he then removed it before the pictures were taken.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
