4.25 stroker crank for small block mopars with 2.0 chevy journals so it will easily fit any small block mopar with minimal grinding and lots of rods to pick from. You could take it a step farther and make it in a kit with good 6.125 I beam rods and pistons you could steal all of hughes thunder with their honda journal crank that only gives you 426 inches.
