If you can make them for less than $500 I will buy them tomorrow!
It would end up being a stock replacement rod for that price , is that what you are looking for ?
There isn't really anything wrong with the eagle rod except it being for a flaoting pin which means the only piston you can use it with is KB piston
Yes! Stock replacement w/1.094 floating. The Eagles have excessive side clearance on the big end, and are too wide on the small end to fit into a KB without modifications. The small end must be narrowed to fit into a KB #162 for 383.
And, whenever possible I prefer to purchase designed in, made in, finished in, distributed in, and owned by America/American.
