Quote: The KB 162 has it's appropriate place in the market even if it's not in a high performance application. Not everybody runs all-out and heads-up.
So, if Howards makes 383 rod, in the USA, I will buy it.
The KB162 has it's place if you want to build a LOW COMPRESSION PIG, .024 in the hole AND a CANYON like valve TROUGH at 5cc ...
As far as the rod , if they make it I'll buy it also , but considering the 383/400 market I'm NOT holding my breath ...
