Based on your cam and intake choice, I think the Edelbrock 650 AVS would be a perfect choice, more than enough cfm and it would make a snappy performer on the street. In my book, it is hard to go wrong with MSD. You did not mention what pistons/compression ratio you will be running and whether you will use headers or manifolds.
