Welcome here. Alot of folks recommend the holley street demon carb. On ign there are lots or pros/cons with MSD. Myself I like an OE 70's dist (& rework the curves & more) with an HEI module & an E coil. EDIT with further checking the RPM is a square bore & the Demon is a spreadbore but there is an adapter but another carb might be better, hang loose others will advize
