Sorry fast, you didnt post it, i got screwed up with my names with all the reading im doing, but here is the post and its close to the bottom https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/2057285/Searchpage/4/Main/175727/Words/%2BE-STREET/Search/true/re-trick-flow-vs-stealth-vs-super-stealth-for-505-build.html#Post2057285
Correction to link CLICK HERE
1968 Charger COLD A/C Hilborn EFI 512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim 2020 T/A 392 Stock 11.79 @ 114.5
