Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info
[Re: an8sec70cuda]
#2666766
06/17/19 09:23 AM
06/17/19 09:23 AM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
I've been told any rubbing at all will burn them up. I have straight 3/8" Mantons in mine, .134" wall IIRC. They are HEAVY. I did a TON of grinding on my KB block to get them to clear. The heads were ok. I appreciate that. Rubbing: No thanks. (Especially not on a thin tube pressed in) My block seems good (Although I've only checked one cylinder), but it's tight to the tube pressed into the head. The Edelbrock heads seem like a costly change of plans, but after seeing them up close, I see why Dwayne and Chuck both steered me that way.
Rich H.
Esse Quam Videri
Entire Thread
ZIPPY
06/14/19 05:36 PM
Cab_Burge
06/14/19 06:01 PM
rickseeman
06/15/19 02:07 PM
hemi-itis
06/16/19 03:17 PM
Cab_Burge
06/16/19 07:54 PM
an8sec70cuda
06/17/19 01:14 PM
ZIPPY
06/17/19 01:23 PM
rickseeman
06/17/19 02:40 PM
ZIPPY
06/17/19 02:52 PM
Cab_Burge
06/17/19 04:50 PM
Hot 340
09/14/21 03:31 PM
Dragula
09/14/21 03:32 PM
Hot 340
09/14/21 03:33 PM
Dragula
09/14/21 09:54 PM
W.I.N. Racing
09/15/21 02:10 AM
Cab_Burge
09/21/21 01:54 AM
ZIPPY
09/20/21 06:40 PM
crowbait
09/21/21 01:58 AM
ZIPPY
09/21/21 04:18 PM
crowbait
09/22/21 03:36 AM
ZIPPY
09/22/21 05:28 PM
crowbait
09/23/21 03:59 AM
BigDaddy440
09/23/21 04:44 AM
ZIPPY
09/23/21 12:09 PM
68 HEMI GTS
09/23/21 07:26 PM
ZIPPY
09/24/21 03:43 PM
Craig J
03/21/24 02:43 AM
ZIPPY
03/21/24 01:08 PM
6PKRTSE
03/21/24 02:35 PM
rickseeman
03/21/24 03:13 PM
6PKRTSE
03/21/24 03:57 PM
hemicar1971
03/24/24 09:13 PM
rickseeman
03/24/24 11:30 PM
rickseeman
03/25/24 01:26 PM
hemicar1971
03/25/24 05:27 PM
rickseeman
03/25/24 10:36 PM
ZIPPY
03/26/24 01:07 AM
hemicar1971
03/26/24 01:25 AM
ZIPPY
03/26/24 05:35 PM
Craig J
03/22/24 01:20 AM
Hot 340
03/25/24 01:43 PM
6PKRTSE
03/25/24 03:23 PM
Hot 340
03/25/24 04:41 PM
ZIPPY
06/17/19 01:17 PM
