That's good thinking there, I did I play with that, and my mockups showed me there was nothing to be gained where I needed it.
Using the trusty Jesel adjustable checking pushrod I tried up to 4 or 5 threads sticking out, I
also tried "the cup just barely clears the underside of the rocker" (meaning no threads sticking out at all)
and neither one really made a licks worth of difference in the area I needed it.
It was worth a try anyway, especially with the 572 being my first Gen 2 Hemi and all/not knowing what to expect.
The easy fix was to not use Indy exhaust rockers on that config
Set it up with around 1 and 1/2 sticking out if I remember correctly.
This is an older thread.......I fired this engine up 4-26-2020, it all worked out.
