Re: Victor Gen2 Hemi heads, exhaust pushrod clearance, info
[Re: 6PKRTSE]
#3222575
03/24/24 05:13 PM
03/24/24 05:13 PM
Posts: 5,117 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Do Stage V roller rockers on an Eddy Jr head have the same push rod clearance problems, I believe their ratios start ar 1.6 but not sure if there are 1.5s or 1.55. The TD are very nice and a friend has them on he 572 Hemi in his race car with the spray bars. I believe both oil via push rod and spray bar is available from T&D just the price is higher that many want to pay. Stock Type rocker from Mopar can be an experience testing to see how close they are in Ratio. Indy is a no for this type of set up. Those guys from Canada HemiGuys that sell both a Roller and Wide pad type of Hemi Rocker anyone used them on a good roller hemi set up with lots of spring pressure and did they survive. Looks like I am going to mock up and see if there is a contact problem in the Push Rod Guide. It was easier to run a 426 Cast iron motor then to go big 572 with Aluminum. Stage V heads out of FHO likely does not have this problem do to the size of the work Banning does on the push rod bushing. This is a good read and anyone used these parts BMBlock, Eddy Jr. Heads should make this a read before ordering or assembling.
1971 HEMI E BODY REGISTRY
Entire Thread
ZIPPY
06/14/19 05:36 PM
Cab_Burge
06/14/19 06:01 PM
rickseeman
06/15/19 02:07 PM
hemi-itis
06/16/19 03:17 PM
Cab_Burge
06/16/19 07:54 PM
an8sec70cuda
06/17/19 01:14 PM
ZIPPY
06/17/19 01:23 PM
rickseeman
06/17/19 02:40 PM
ZIPPY
06/17/19 02:52 PM
Cab_Burge
06/17/19 04:50 PM
Hot 340
09/14/21 03:31 PM
Dragula
09/14/21 03:32 PM
Hot 340
09/14/21 03:33 PM
Dragula
09/14/21 09:54 PM
W.I.N. Racing
09/15/21 02:10 AM
Cab_Burge
09/21/21 01:54 AM
ZIPPY
09/20/21 06:40 PM
crowbait
09/21/21 01:58 AM
ZIPPY
09/21/21 04:18 PM
crowbait
09/22/21 03:36 AM
ZIPPY
09/22/21 05:28 PM
crowbait
09/23/21 03:59 AM
BigDaddy440
09/23/21 04:44 AM
ZIPPY
09/23/21 12:09 PM
68 HEMI GTS
09/23/21 07:26 PM
ZIPPY
09/24/21 03:43 PM
Craig J
03/21/24 02:43 AM
ZIPPY
03/21/24 01:08 PM
6PKRTSE
03/21/24 02:35 PM
rickseeman
03/21/24 03:13 PM
6PKRTSE
03/21/24 03:57 PM
hemicar1971
03/24/24 09:13 PM
rickseeman
03/24/24 11:30 PM
rickseeman
03/25/24 01:26 PM
hemicar1971
03/25/24 05:27 PM
rickseeman
03/25/24 10:36 PM
ZIPPY
03/26/24 01:07 AM
hemicar1971
03/26/24 01:25 AM
ZIPPY
03/26/24 05:35 PM
Craig J
03/22/24 01:20 AM
Hot 340
03/25/24 01:43 PM
6PKRTSE
03/25/24 03:23 PM
Hot 340
03/25/24 04:41 PM
ZIPPY
06/17/19 01:17 PM
