The hole that connects the two sides of the leak down tester is pretty small....... so it doesn’t take much of a leak to not be able to build pressure. If the leak is bigger than that orifice in the gauge...... you’ll get nada.
That being said, the only way I can see it being a ring issue is if the comp rings are either broken, or........stuck/seized into the ring grooves.
Be interesting to see what you find.
Did you happen to do a compression test on that cyl as well?
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
