The best oil pressure you are going to get with a drill motor will depend on the rated HP of the drill motor. A "Good" HV oil pump (for a BB MOPAR) will flow just under 20GPM/min,. To generate 40 psi with a 95% efficient pump you will need at least .5HP - 60psi will require .75HP. Now if the pump become less efficient (75%) you will need 1HP to generate 60psi. All that being said looks like your in the ball park.( this is a simplified explanation without corrections for oil viscosity differences but gets the point across)
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
