I'd get it running and see what pressure it runs at warm (at your intended RPM limit). If you are going to beat on it I like to see 60-70 at 7000. If its low try adding a shim behind the relief valve spring. If that doesn't do it then swap the pump. its no big deal. Idle pressure really doesn't matter. Doug
