What do you think about that prop valve under my master cylinder, does it look correct for 4 wheel disc? Is there any tricks to bleeding Wilwood calipers since they are 4 piston? I do the top 2 bleeds, then try to flip it up or over to do the bottom bleeds while they're facing up. I may not be doing it correctly.
