Andy , I misunderstood . "What rocker arms do you have now? The 270 uses standard rocker arms so what you have might work." OP has Crane rockers for standard port Stealth heads . Thanks for your input
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
