Hi all,
I am trying to decide on Victor or Trick flow heads.
The engine is a 500" 440 based engine with 11.5:1 compression. I have a solid roller cam forget the specs right now. I have a Super Victor intake and a 1050 Dominator. Crank trigger with a 7al ignition. The converter is an 8" 5500 in a 727. The rear is a Dana with 4:30 gears. The car is strip only and weighs 2800 with driver. Not sure which heads to look at. So I am putting this out to get opinions. I know the compression is down a bit but the engine was going to be used as a street strip thing when originally built.
Thanks, Digger73 (Mike)
