I pulled it last Friday to look it over. It looks Ok, its not great and it not bad, on three of the rod bearing the coating looks like it flaked off on the top of the bearing. The main bearings look good, cam bearing are showing some wear but that's expected with the spring pressures and RPM I am running. Piston skirts looked good nothing to be worried about.
