[quote=MR_P_BODY]What is the deck height and lifter angle on these blocks
This one is a tall deck (9.6") 48 deg. you can get a short deck and what ever lifter angle. [/quot
What you have is what I'm looking for... thats why I will watch your build... I have a set of W-9 for one
I have a set of W9's on my other R3 block (468 cid) with 59 deg lifter angle. That set of heads is a set of Chapman done heads and they are to small for that motor it gives up at 6800 but it pulls hard in the mid range. This one is going to get the W9RP that Curtis Boggs from RFD did.
