Update, I took it to the track tonight first time since I hit the deer on DW2014, I was planning on making three hits two, 1/8 mile and one 1/4 mile. The track scales said 3397 lbs., full exhaust and 28x 10.5 slicks the only decent pass it went 10.552@130.67mph. Still having problems with the new shifter hanging up between 2nd and 3rd gear, on the 10.55 pass I still fought that gear change(Slow). Motor seems to be happy good oil pressure all night, oil is clean. Just finished the leak down and compression test all was good, Leak down on all cylinders were below 4% and the compression was all with in 6 psi. I plan on cutting oil filter in the morning. I think there is a lot more left in this motor, my tune was very safe, 30 deg. timing and A/F ratio was rich.
