Originally Posted By fast68plymouth
In the OP's case, he's using EDM direct oiling lifters.
Oil pressure had nothing to do with the result here.
I read that. I've never used them. It would seem that if the volume of oil was down, it would also be down with the lifter oiling.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
