Originally Posted By sgcuda
You might still have another issue. Worn cam lobes won't cause oil pressure issues.
thats why I am going back through it, the oil pump drive bushing was worn real bad also.
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
