With been through this debate a few times in the heads up stuff. We have shown as have others that in terms of HP it is a wash between a dry and wet sump. Lobbying to get penalties removed from a dry sump set up was the motivation. They have changed the rule to a 5% addition for a dry sump which is down from 10% but still wont do away with that rule. It benefits us now as we run a wet sump system now. The dry sump shines in two areas, oil control and generally speaking the ability to pull more vacuum. Although we can pull 20" on a wet sump...
