Too bad you don't know someone near you with a stock(or stock-ish) 400-3 you could use for a quick back to back test.
I already ran the 400-3 in stock form and it wasn't anything great. I have the Wilson M1 to use as the control sample since I also ran it on the last dyno test. I don't think I need two control samples.
