I realize this has yet to be tested, but for a RB block and the 270 head, what would the preferred intake be? I am running a 4150 now, so I would likely run an adapter on the Dommy intakes
Super Victor, port-matched TF, 440-3?
C.I.? C.R.? Application? Planning to switch to a Dominator-type carb?
All I can say at this point is a port-matched (if you can even get it that big) standard-port intake would be my last choice.
