We'll have our 270 heads soon...hope we don't go outside the usable rpm range of the hyd. roller cam with them.
Andy are you going to try the edelbrock Victor MW intake on the 270 heads?
I'm on a low deck so my Wilson prepped Super Victor will not fit. If that intake would fit then it is the one I'd use. (although the ports in that intake are larger than the small window ports that TF put in the 270 head)
