The one thing I am wondering is you said the first time it happened you also had no third gear ? The rear band fried will not effect third gear. Third is the front and rear clutches in the main trans unit. Course power also goes through the O/D direct clutches in first through third. So I was curious about that as you said you found no other problems in it ? Ron
