It makes absolutely no sense to me to adjust preload on an empty lifter. Adjusting a fully filled lifter will ensure you can feel it at "zero" and then add your preload.
This is why I suggest priming the motor - to ensure all 16 lifters are full.
FWIW, you can't tell me that everyone who does a periodic adjustment removes and drains their lifters before adjusting them !!
