My bad. I meant to say lube the outside of the lifters,but don't fill them up before adjusting them.Sorry if I led somebody wrong.
Coke,if you have some lifters that won't bleed down even when you put pressure on them and the valves are opening when you try to adjust,you might have to pull the lifters and take them apart to drain oil out.Make sure they are clean.
