What about the engine mounts? I've heard a lot of conflicting stuff about it.
Originally Posted By jerseybud
2. Luckily dodge kept the motor mount ears cast into the block all the way thru 2000 on the 318 and 2003 on the 5.9. Just need the brackets which you should already have on your LA
jerseybud nailed it. Our '93 Ramcharger has a '97 318 replacing the original, no mount modification required. The later mounts are just along for the ride.
