That will work for me do you have plans for an air pan?
Yep. I've already cut out a cardboard template and will be making it out of a thin piece of wood panel, same stuff that I used with my previous one. It did such an effective job of reducing heat transfer that you could put your hand on the top of the hood and feel the temperature difference between where the hood was exposed to engine heat and where it was noticeably cooler above where the air pan sealed up against it.
was there an performance advantage with the seal hood?
A solid .1 improvement in ET and 1 MPH increase over the same old scoop and no air pan.
