I've gone back & forth on the VFN 5" T/A scoop that Rick R. and some others run for longer than I've been considering doing the Landy band-aid mod. On his solid 9-second car it looks cool. On mine... I think it would look like I don't have the car to back up the scoop.
Have Monte send you a kit. Then you could run nines too (if you were running). Problem solved.
