Originally Posted By AndyF
'69 RoadRunner with a big block and a driver is probably around 3500 lbs. Wallace says 128mph at 3500 lbs is 565 hp.
I wish , my 68 Satellite is around 3660-3700 with me and I'm built like a whippet.
I have all the aluminium engine add ons , fibreglass bonnet and front bumber , aluminium wheels . I am not sure I would get that low without gutting the interior - removing bench seat heater etc
You are going to have to help your 60' first then look from there .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
