Originally Posted By BradH
CR?
60 ft?
I wouldn't expect a big gain from a cam swap, but you could try 1.6s (only on the intakes since you already have more exhaust duration) to look for a small gain.
Do you have a hood scoop? If so, is the carb sealed to the scoop?
Exhaust system? Do you run open headers?
Let me also ask what the converter slippage % is, the 1/8 mile ET & MPH, and the RPM going thru the traps in the 1/4...
