Originally Posted By BradH
CR?
60 ft?
I wouldn't expect a big gain from a cam swap, but you could try 1.6s (only on the intakes since you already have more exhaust duration) to look for a small gain.
Do you have a hood scoop? If so, is the carb sealed to the scoop?
Exhaust system? Do you run open headers?
iagree is your chassis working right... the 60'
will tell you how well it is.. if you run exhaust there
are muffs that just plain dont work well.... but your
looking for .3-.4..thats a fair amount
wave
