The GTX needed a bath very bad by the time we got to Kenosha. My dutiful Trunk Monkey made good use of the Hotels hose. Kurt Johnson, Winner of Street Race BBNA, is in the back ground with his BBC powered Mustang. Runs; low nines/high 8's.
The sign says it all:
Jeff needed a challenge, (among other things)and my car was easy to deal with, so he helped out Jay a bit. Jay made about 8 passes at Great Lakes Dragaway, because a loose wire was shutting the car off at half track. Finally he found the problem, and went out for another pass in the 8's. At this point, he was leading the big block naturally aspirated modified class.
