i may run it like this with the single and nos my tunes have worked very well so far ,the sheet metal and nitrous will be the crazy deal. the heads are patterson racing and have had a some work done over here by a top pro stock team engine builder.E T A is slow due to sudden setbacks like the r block had a 5 inch crack in the new block its been hard to sauce another r3 but by xmas here with luck. [img:center][/img]
What size valves are you running?
Brett Miller W9 cnc'd heads STR Chassis fabraction
